Disconnect problem Happy Src
I got error Disconnect game when login into game. Select character, move around map and got dis. Either NPC and mobs not load. Anyone got this error ? Help me with this or can dm me for your help
Tks all
This error usually indicates that the client managed to enter the map, but lost communication with the GameServer or an error occurred while loading the map. Since you mentioned that NPCs and monsters don't appear, this helps narrow down the causes considerably.
The most common checks are:
Incomplete or incompatible map field between client and server.
Different map files (ASE, INX, OBJ, BGM, etc.).
Incorrectly configured FieldList or Stage.
Error loading NPCs or monsters on the server.
Read error in the database or NPC files.
Silent GameServer crash when entering the map.
Invalid Warp or Spawn coordinates.
If the problem only occurs on some maps, it's almost always a problem with the Field or the configuration of those maps. If it happens on all maps, it's worth checking the GameServer, the logs, and the NPC/monster configuration first.
